adamkuz
Машина VW TOURAN 1.9 TDI 2007
Подскажите пожалуйста как разблокировать Webasto имея кабель VAG908 (USB VAG/ISO interface) и соответсвующее програмное обеспечение.
Подключившись к машине програма выдаёт такую ошибку в обогревательной системе:
Address 18: Aux. Heat Labels: None
Part No: 1K0 815 071 R
Component: Zuheizer 050 2302
Revision: 00050000 Serial number: 09009839000000
Coding: 0000011
Shop #: WSC 01324 785 00200
3 Faults Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 19
Reset counter: 41
Mileage: 44235 km
Time Indication: 0
01415 - Recirculating Pump (V55)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 189
Reset counter: 48
Mileage: 53041 km
Time Indication: 0
Freeze Frame:
Locked
Temperature: 80.0°C
Temperature: 80.0°C
Voltage: 14.45 V
02251 - Heater Unit Locked
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 8
Mileage: 53530 km
Time Indication: 0
Благодарю за ответы.
Coding: 0000011
3 Faults Found:
00664 - Fuel gauge
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 41
Mileage: 44235 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Reset counter: 48
Mileage: 53041 km
Time Indication: 0
Freeze Frame:
Locked
Temperature: 80.0°C
Temperature: 80.0°C
Voltage: 14.45 V
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 8
Mileage: 53530 km
Time Indication: 0
