Сброс межсервисных интервалов SEAT при помощи кнопок на приборке
  • Автор темы ten70
  • Ответы 0
  • Просмотры 13К
ten70
ten70
Оракул
AD1 R-Line TDI
SEAT
Arosa 1997 – 2000
OIL – Oil service
1. Press and hold button A
2. Switch the ignition on
3. Keep button A depress until --- appears in the display
4. Release button A
5. Switch the ignition off
INSP – Inspection service
1. Press and hold button a
3. Keep button A depressed until --- appears in the display
4. Release button A
Ibiza / Cordoba 1993 – 1999
Inca 1995 –
OEL – Oil service
3. Switch the ignition off
4. Release button A
5. The word “OEL” will appear
6. Press the clock minute button B until ---- appears in the display
7. Switch the ignition on until the letters IN00 display
IN01 – Inspection service
4. Release button A
5. The word OEL will appear
6. Press button A to display IN01
7. Press button B to display ----
8. Switch the ignition on until the letters IN00 appear
Inca 1995 –
IN02 – Inspection service
4. Release button A
5. The letters OEL will appear
7. Press button A to display IN01
8. Press button B to display ----
9. Repeat procedure to reset IN02
10. Switch the ignition on until the letters IN00 appear
Toledo 1994 – 1999
OIL – Oil service
1. Switch the ignition on
2. Press and release the clock hour button A
3. The letters OEL will appear
4. Press the clock minute button B until ---- appears
3. Press and release the clock hour button A again
4. The letters IN01 will appear
5. Press the clock minute button B until ---- appears
6. Clear the OEL indicator as described previously
7. Switch the ignition off
3. Press and release the clock hour button A twice more
4. The letters IN02 will appear
5. Press the clock button B until ---- appears
6. Clear the OEL and IN01 indicator as described previously
Leon / Toledo 1999
OIL – Oil service
3. Release button A
4. The letters OEL or OIL will appear
5. For models with digital clock turn button B to the right until - - - - appears
6. For models with analogue clock pull out button B until - - - - appears
3. Release button A
4. Press and release button A
5. The letters INSP will appear
6. For models with digital clock turn button B to the right until - - - - appears
7. For models with analogue clock pull out button B until - - - - appears
Ibiza / Cordoba 1999 –
Leon 2000 –
Toledo 2000 –
1. Press and old button A
3. Turn button A to the right for 1 second
4. The display will now read clear
5. Release button A
6. Switch the ignition off
Alhambra 1995 – 2000
OEL – Oil service
1. Press and hold the reset button A
3. ---- will appear
4. Switch the ignition off
5. Release button A
3. ---- will appear
5. Release button A
3. ---- will appear
5. Release button A
Alhambra 2000 –
Vehicles on longlife service cannot be reset
Fixed service interval reset as follows
3. The word “service” will appear
4. Release button A
5. Turn button B to the right to reset the display
Info:
Vehicles with long life service intervals (some Audi/Skoda/Seat/VW) cannot be reset using these procedures, only cars (some Audi/Skoda/Seat/VW) with fixed interval servicing can be reset. It’s a VAG thing.
I take No Responsibility over your actions whatever may happen, you reset your service light at your own risk
If your service light wont go out on your first try have a few tries sometimes its hard to do.
Please note where “– “is shown, this means tested up to year 2002
I hope you find these procedures informative and useful.
Disclaimer
Resetting your service light is not a substitute for servicing your vehicle. Obey your manufacturer's suggested service intervals.
