Admin
Создатель сайта
Команда форума
- Россия, Москва
- VW Tiguan 2.0 DBGC 2018, VW Touran 1.6 BSE 2008
Двигатель 2E (Digifant):
Спасибо: _VanDal_
Digifant injection and ignition system Fitting locations overview
1. 4 pin connector. For Lambda probe (G39) On engine mount - Right
2. Pressure regulating valve for crankcase breather
3. Idling adjustment screw
4. Throttle valve potentiometer (G69)
5. Throttle valve housing
6. Digifant injection and ignition system control unit (J169)
7. Intake manifold
8. CO sampling pipe
9. Fuel pressure regulator
10. Fuel rail
11. Injector (N30...N33)
12. Ignition transformer (N152)
13. Idling stabilization valve (N71)
14. Distributor
15. Coolant temperature sender (G62) with coolant temperature indicator sender (G2)
16. Knock sensor 1 (G61)
17. Earth connection
18. Intake hose
19. Temperature regulator For intake air preheating
20. Air flow meter With sender for intake air temperature (G42) and potentiometer (G19)
21. CO-Potentiometer (G74)
22. Air cleaner
Спасибо: _VanDal_
7. Intake manifold
8. CO sampling pipe
10. Fuel rail
14. Distributor
18. Intake hose
22. Air cleaner
