ten70
Оракул
- AD1 R-Line TDI
VW Beetle 1998 – 1999
OEL or OIL – Oil service
1. Press and hold Button A
2. Switch ignition on
3. The letters OEL or OIL will appear
4. Release button A
5. Press and release button A
6. The letters INSP will appear in the display
7. Press and hold button A until --- appears
8. Release button A
INSP – Inspection service
1. Press and hold button A
2. Switch the ignition on
3. The letters INSP will appear
4. Release button A
6. The letters OEL or OIL will appear
8. Release button A
If required clear the OEL or OIL indicator as described above
VW Beetle 1999 – 2000
3. Release button A
4. The letters “service” will appear in the display
5. Press and hold button A until the word “service” is erased
6. Switch ignition off
VW Beetle 2000 – 2002
Vehicles on fixed interval servicing can be reset as follows:
3. Release button A
6. Switch the ignition off
VW Lupo 1998 – 2002
VW Polo 1999 – 2002
VW Polo Classic / Estate 1999 – 2002
OIL – Oil service
3. Keep button A depressed until --- appears in the display
4. Release button A
5. Switch ignition off
4. Release button A
6. If required clear the OIL indicator as previously described
VW Polo (excluding 1.9D AEF engine) 1994 – 1997
VW Polo Classic / Estate (excluding 1.9D 1Y engine) 1996 – 1999
VW Golf/Vento/Cabrio(excluding 1.9D 1Y engine 1996 -)1991 – 2002
VW Caddy (excluding 1.9D 1Y engine) 1996 – 2002
OEL – Oil service
1. Switch the ignition on
2. Press and hold button A
3. Release button A
4. The letters OEL will appear
5. Press the clock minute button B until ------ appears in the display
6. Switch the ignition on until the letters IN00 appear in the display
IN01 – Inspection service
3. Switch the ignition off
4. Release button A
6. The letters IN01 will appear
7. Press clock minute button B until ------ appears in the display
8. Press button A to display OEL
9. Press button B to display -------
10. Switch on the ignition until the letters IN00 appear in the display
IN02 – Inspection service
4. Release button A
5. The letters IN01 will appear
6. Press clock minute button B until ------ appears in the display
7. Press button A to display IN01
8. Press button B to display ------
9. Repeat the procedure to reset OEL
10. Switch the ignition on until the letters IN00 appear in the display
VW Polo 1.9D (AEF engine) 1995 – 1997
VW Polo Classic / Estate (1Y engine) 1996 – 1999
VW Golf / Vento 1.9D (1Y engine) 1996 – 1999
VW Caddy 1.9D (1Y engine) 1996 – 2002
OEL – Oil service
4. Release button A
5. The letters OEL will appear
7. Switch the ignition on until the letters INSP-0 appears in the display
INSP-1 – Inspection service
2. Press and hold button a
4. Release button A
5. The letters INSP-1 will appear
7. Press button A to display OEL
9. Switch ignition on until the letters INSP-0 appear in the display
INSP-2 – Inspection service
4. Release button A
6. The letters INSP-2 will appear
8. Press button A to display INSp-1
10. Repeat the procedure to reset OEL
11. Switch the ignition on until the letters INSP-0 appear in the display
VW Polo 1998 – 1999
OIL – Oil service
3. Keep the button depressed until ---- appears in the display
4. Release button A
5. Switch the ignition off
3. Keep button A depressed until ---- appears in the display
4. Release button A
6. If required clear the OIL indicator by following previous procedure
VW Golf / Bora 1997 – 1999
OIL – Oil service
3. The letters OIL will appear
4. Release button A
5. Turn button B to the right until ------ appears
4. Release button A
7. Turn button B to the right until ------ appears
8. If required clear the OIL indicator by following the previous procedure
VW Golf / Bora 1999 – 2000
VW Passat 1999 – 2000
3. The word service will appear
4. Release button A
5. Turn button B to the right to reset the display
VW Passat 1996 – 1999
OEL – Oil service
3. Release button A
4. The word OEL will appear in the display
5. For models with a digital clock turn button B to the right until ---- appears in the display
6. For models with an analogue clock pull out button B until ---- appears in the display
1. Press ad hold button A
3. Release button A
4. Press and release button A
5. The work INSP will appear in the trip recorder
6. For models with a digital clock turn button B to the right until ---- appears in the display
7. For models with an analogue clock pull out button B until ---- appears in the display
8. If required clear the OIL or OEL indicator as previously described
VW Golf / Bora 2000 - 2002
VW Passat 2000 – 2002
VW Sharan 2000 – 2002
Vehicles on fixed interval servicing can be reset as follows.
4. Release button A
VW Sharan (models with trip computer) 1995 – 2000
OEL – Oil service
3. Four dashes will appear in the display
4. Switch the ignition off
5. Release button A
1. Press and hold reset button A
5. Release button A
6. Clear the OEL indicator as previously described
5. Release button A
6. Clear the OEL and IN01 indicators as previously described
VW Sharan (models with adjustment button for trip recorder) 1995 – 2000
4. Release button A
5. Turn button B to the right until the word service is erased
VW Transporter T4 1999 -
OEL – Oil Service
3. Release button A
4. The word OEL or OIL will appear
5. Turn button B to the right until ---- appears in the display
3. Release button A
VW Transporter TDI 05 1999 – 2002
VW Transporter V6 24V 2000 – 2002
4. Release button A
Info:
Vehicles with long life service intervals (some Audi/Skoda/Seat/VW) cannot be reset using these procedures, only cars (some Audi/Skoda/Seat/VW) with fixed interval servicing can be reset. It’s a VAG thing.
I take No Responsibility over your actions whatever may happen, you reset your service light at your own risk
If your service light wont go out on your first try have a few tries sometimes its hard to do.
Please note where “– “is shown, this means tested up to year 2002
I hope you find these procedures informative and useful.
Disclaimer
Resetting your service light is not a substitute for servicing your vehicle. Obey your manufacturer's suggested service intervals.
4. Release button A
8. Release button A
4. Release button A
8. Release button A
3. Release button A
3. Release button A
VW Lupo 1998 – 2002
VW Polo 1999 – 2002
OIL – Oil service
4. Release button A
4. Release button A
OEL – Oil service
3. Release button A
4. Release button A
4. Release button A
OEL – Oil service
4. Release button A
4. Release button A
4. Release button A
VW Polo 1998 – 1999
OIL – Oil service
4. Release button A
4. Release button A
OIL – Oil service
4. Release button A
4. Release button A
4. Release button A
OEL – Oil service
3. Release button A
3. Release button A
4. Release button A
OEL – Oil service
5. Release button A
5. Release button A
5. Release button A
4. Release button A
OEL – Oil Service
3. Release button A
3. Release button A
4. Release button A
Info:
Disclaimer
